ANYONE OUT THERE KNOW HOW EXACTLY TO REMOVE THE DRIVER AND PASSENGER AIRBAG FROM A 96 CIVIC DX? WHAT ARE THE EXACT STEPS AND PROPER PRE-CAUTIONS THAT SHOULD BE TAKEN? I WOULD REALLY APPRECIATE IF ANYONE CAN HELP ME OUT! THANKS IN ADVANCE...
drummerboy858 said:when i built my car, just left the battery out, removed the driver side one out of the steering wheel. took the control unit (SRS unit) out from under the center of the dash. i dont think the passenger side one can be removed as it would ruin your dash. i dont think it will come out from the bottom either.
search a lil better next timeCrash&Burn said:Unplug the battery, push the brakes in a few times to dispel any eletrical buildup, then to take off the driver side you go to the bottom of the steeringwheel area, and there is a plastic pop out peice. Go in there, and remove the yellow wiring harness. Then, on the sides of the steering coluwn are two more smaller plastic peices. Using a TORX 25 head, you remove the screws that are there. I don't remember how many, but it was probably 2-3. Then, you carefully remove the bag.
To remove the passanger one remove the glove box, and then on your left there is a wiring harness. Again, disconnect the yellow peice that will be leading to the left side of the airbag as you are sitting in the car. Then, there are three screws in the front, but I don't remember their size. Remove those, then have someone help you remove it by having them push it in and up from the inside of the car, and you guide it straight up.
