80 sounds good! It's all in the setup, with regards to safety. Make sure you've got the rev limiter set high enough or the fuel will cut off while the nitrous is jetting. bye bye engine. I'm sure you know you should only spray between 3500-7500 rpm *depending on your car. Usually, lay off at Redline, and don't hit the button till your around halfway through the powerband.
