Valet units have a negative activation input(newer models have + aswell)
If you have trunk pop or something of that nature, you would connect the trunk pop of the Karr unit the activation input of the Valet.. and press the trunk pop when you want to start the car, get it?
usually, yes, you almost always can..
theres no install specs on it, but just goin by the description, i dont think you can use a valet system with a Karr system, it doesnt have any outputs(trunk,window), so how could it activate the Valet?
You could probably add-on a Karr remote starter since they can probably integrate, but a 2 channel unit usually means it only has 2 channels, arm/disarm..
do you have a 2 button remote or 3 button?
the demo shows a 3 button, with 1 channel doin arm/disarm, 2 channel doin trunk, and 3 doin panic.. this is what you have?
even with a 2 button remote its still possible, you can press both buttons at the same time to active the extra channel. for example my remote has 4 buttons but i can arm, disarm, panic, remote trunk, window down, and remote start.
