Had my alignment done today at Best Tire in Great Neck, NY. They utilize a state of the art Hunter laser alignment rack. What follows is my final specs and the factory specs as well
17x7 CL-S Wheels
Dunlop SP Sport 4000 215/50-VR17
Eibach Sportlines
Factory Dampers
Front Left
Camber: -0.4 degrees (Factory Spec: -1.0 to 1.0 degrees)
Caster: 3.0 degrees (Factory Spec: 1.8 to 3.8 degrees)
Toe: 0.02 degrees (Factory Spec: -0.08 to 0.08 degrees)
Front Right
Camber: -1.1 degrees
Caster: 2.4 degrees
Toe: 0.01 degrees
Front Total Toe: 0.03 degrees (Factory Spec: -0.16 to 0.16 degrees)
Rear Left
Camber: -1.6 degrees (Factory Spec: -1.0 to 0.0 degrees)
Toe: 0.08 (Factory Spec: 0.00 - 0.16 degrees)
Rear Right
Camber: -2.3 degrees
Toe: 0.09 degrees
Rear Total Toe: 0.21 degrees (Factory Spec: 0.00 to 0.32 degrees)
So as you can see, no camber kit is needed for the front wheels, only frequent alignment is necessary, esp since i hit potholes from time to time. However my rear camber is pretty bad, probably necessitating a camber kit (Ingalls part#3872) Although the rear tires are NOT subjected to very much load, peace of mind is worth $200
17x7 CL-S Wheels
Eibach Sportlines
Factory Dampers
Front Left
Front Right
Caster: 2.4 degrees
Toe: 0.01 degrees
Rear Left
Rear Right
Toe: 0.09 degrees
