i had 205/50 on stock wheels with about 1.5 degrees negative camber in the rear and almost 2 degrees negative in the front.
i got front camber kits right away, but put off getting rears....til i had a blowout on the freeway cause i wore it down to the steel on the inside of the tread. i would recommend gettig kits for the front and then doing the longer screw and 3 washers for the rear. the washers should add about .75 degrees of positive camber to the back making it near perfect...
