hi i just recently tighten my timing belt, it was rather loose.
since then i've had this check engine code. always the same 6 codes. (cylinder 1,2,3,4 misfiring and random misfiring.)
i took it to a dealership and they told me my compression for cylinder 1 is at 180 and the rest are at 200 and that they couldn't determine the reason for the misfiring cause i had to much mod on it. they think that the problem might be from when i hydrolock my engine 7 months ago.
i am wondering if it can have something to do with my timing belt.
here is the mod spec on my car
Unorthodox pulley/cam gear/ crank pulley. the timing was advance but i took it to a shop and set it back to normal before i tighten my timing belt.
i took it to a shop yesterday and they told me i had to replace my Unorthodox cam gear to stock so i can adjust my timing and fix the compression on cylinder 1.
what you guys think i should do?
blown head gasket you think?
