I heard the other day that i can significanly increase my compression by swapping b20 pistons into my b16a2. How wise would this be and how could I do it safely.
won't work at all. bore on B20 pistons is 84mm2000redCIVICsi said:I heard the other day that i can significanly increase my compression by swapping b20 pistons into my b16a2. How wise would this be and how could I do it safely.
Like brandon said, hes done all of that already, and he has all the experience. He had 12.5:1 cr, and lowered it to 12.0:1 with a turbo headgasket because it was too high for a daily driver running off 91-93 octane. Might be something to think about.BrokenLimits said:an LS block. done
Bored/Hone to 81.5 mm done
81.5mm Endyn Rollerwave Pistons ~12.5:1 CR (JE) done
Eagle rods done
ACL rod bearings, ARP head studs and main studs, and all new gaskets, bearings, belts, etc etc. done
Buddy Club Spec IV camshafts Might be Skunk2 Stage 3s
Omnipower or Rocket full valve train Supertech
Good header, intake, exhaust. intake manifold setup done
It'll barely increase your displacement.. If I had the bore/stroke specs on hand in front of me, I'd figure it out, but I don't, haha.2000redCIVICsi said:damn, the bore and honing would be very good for m little 1.6L because 1) its tiny and displacement is always good. 2) My motor has 131,000 miles on it, and new walls would be nice
what color smoke? white/blueish? black?2000redCIVICsi said:im thinking ill hone it out pretty soon, starting to a tiny whisp of smoke when vtec kicks in
