My vtec kicks in at 5000rpm but doenst really pull at all untill 6500.....Is that normal?....I road in my friends '97 prelude and it kicked in and started pulling hard. Should mine do that? THX.
Ok, ill change it to 5500 then...And one more thing. I was reading about vtec the other day and someone said the stock tac is usually off from the controller settings...Is that true?gurusan said:5500 rpm without debate.
Set your VTEC back up to 5500 RPM where it belongs.2Triple0SI said:My vtec kicks in at 5000rpm but doenst really pull at all untill 6500.....Is that normal?....I road in my friends '97 prelude and it kicked in and started pulling hard. Should mine do that? THX.
Ok, thx for the help.gurusan said:The stock tach has a tendency to be off at very high RPMs...but mine is on 100% and so is my friends' Si. I think people exaggerate.
be careful with VTEC controlers......if not tuned right they can destroy a motor. my brother-in-law put one on his 99Si.......and didn't have it tuned right and it through a rod through his block from not being set right. so be careful.2Triple0SI said:Your guess is as good as mine...I have an apexi vtec controller but I didnt put it on there.....I think the person that had it before me got it and just screwed around with it...What do you think the best setting would be to get the most power?
Yea, well there is a honda tuning shop that can fix it up for me so im gonna let them get it all back to normal.killer B said:be careful with VTEC controlers......if not tuned right they can destroy a motor. my brother-in-law put one on his 99Si.......and didn't have it tuned right and it through a rod through his block from not being set right. so be careful.
Good call, trust no one2Triple0SI said:Yea, well there is a honda tuning shop that can fix it up for me so im gonna let them get it all back to normal.
that and the H22 does have a bigger motor hence more torque and hp.Targa250R said:Set your VTEC back up to 5500 RPM where it belongs.
As for your friend's car, the H22A4 has the VTEC engagement set too high from the factory and therefore suffers losses in the torque curve just prior. This is why there is a noticeable change in the Prelude's torque curve once VTEC engages. Lowering the VTEC engagement point for that particular engine will smooth out the curves.
ChewiSi said:that and the H22 does have a bigger motor hence more torque and hp.
Well ive read that there are actually 10 different vtec settings.....2 each gear for engagement point and disengagement...So that could be why.syntetyc said:Since you've been talking about when Vtec kicks in, I would like to share something. I have a '96 coupe LX with a 90' B16a Swap (weird, i know), controlled by a PW0. It's supposed to all be working fine but my Vtec enters at different RPM's each gear.
1st- 4,500
2nd- 5,300
3rd- 5,800 ...and so forth.
My engine does not limit. I can take it up to 9k with out a problem.
Now I ask you gurus, how's this possible?
y your at it have them take it off, i'm not a huge fan of them things2Triple0SI said:Yea, well there is a honda tuning shop that can fix it up for me so im gonna let them get it all back to normal.
Well I did consider taking it off and just selling it...Kinda seems like its more trouble than its worth.J_fukin_t said:y your at it have them take it off, i'm not a huge fan of them things
