when i did it b4 i removed the brake master cylinder...but i dunno if you want to bleed yer brakes afterwards because thats a bitch to do. others say theres a way to take it out from under the car.
That sounds easy enough I am getting my B16a soon so I will have to remember that...jessecrx said:I have a b16a in my rex and the way the engine is mounted it leaves NO room to take the alternator out from the bottom and you cant fit it out from the top. So all had to do was unbolt the brake master cylinder and bend it to the side a bit with the brake lines still attached. It wont hurt it as long as you dont kink the lines. More than enough room to slide the alternator out.
Taking it out of the bottom sounds like a puzzel. If you only have to unbolt the master cylinder than thats alot easier then shifting parts all over the place for no reason.88 rex said:That's the other popular way, and only way i would take it out of the top.
Well I think there is some sort of drill bit that you can drill in there and then pull the old bolt out. You definately going to need new bolts...CRXBitch said:What he keeps having problems with is getting it unattached and out.... it's still in there. The bolts and pin were all rusted and he tried to unscrew them but it just wore away and then it broke off inside so now theres nothing to grab onto. This is the biggest pain in the ass and he has to have the car fixed for my friend by friday and we tried calling around for the parts (lower mounting bracket, the pin & bolt and the other two bolts but every1 keeps saying that dont have it. I just dont know what to do know.... :confused
