ShabsterTL said:
I tried those steps quite a few times, but doesn't seem to work.
here dont know what car you have: try all haha
3.5RL 1996-02 To reset "MAINTENANCE REQUIRED" light, turn ignition off, press and hold the SELECT and RESET buttons. Turn ignition and hold buttons for 10 seconds until the indicator resets.
2.2CL, 2.3CL, 2.5TL, 3.0CL, 3.2TL 1995-01
To reset "MAINTENANCE REQUIRED" light, insert the ignition key into the slot to the left of the light on the instrument panel.
Integra 1994-00 To reset "MAINT REQD" light, press the reset switch located to the right of the steering column under the dash.
Legend (without Information System) 1988-90 Reset "MAINTENANCE REQUIRED" light by inserting the ignition key into the slot located directly below the light.
Legend (with Information System) 1988-90 When "OIL/FILTER CHANGE DUE" is displayed on the Information System, press the "SERVICE RESET" button for three seconds. This will reset the system to 7,500 miles. If you want to set a shorted interval, press the "SERVICE RESET" button and the arrow button together for three seconds. Then push the arrow until the mileage that you want to set is shown on the display, push the "SET" button.
