i also have another noise issue, so i figured instead of making a new thread to just ask on this one. this one is SUPER annoying! its sorta a rattle but sorta a grinding (its hard to describe). it started after i put my header and exhaust on and does it at around 2k-3k under certain percent throttle? it also does it when i turn? i thought it was my exhaust rubbing my heat sheild some place but i looked and nothing is rubbing.
the only thing it think it could be.... bare with me... IS, i have a greddy header and the mounting plate that mounts right above the oil pan doesnt reach so i never connected it, is there suppost to be a seperate plate that connects the bracket to my block because it doesnt seem like it would reach even if i forced it? if there is suppost to be a mounting plate that fills the gap from the bracket to the block (above the oil pan) then i never got it.
