I have tried searching on this but with no results.Has anyone else had a high pitched whistle coming from the hvac system.I tried putting the tape around the entire windshield so i know it is not the seal.It only occurs with the recirculate on,and a window or roof cracked, above 50 mph.Before anyone bashes, I need the recirc on due to bad allergies here in the south, the window needs to be cracked just so I don't suffocate.It does not make the noise if I put the fresh air button on.If someone else has had this problem and fixed it please help, thanks in advance.
