hi i have a 1991 honda accord dx with a good history lol
car has been in a flood twice *not running while flooded* and just deep enough to submerge the ecm and tcm incase i need to check something from that
basically to describe this idle issue
first i start the car idle is perfect starts off at 1200 or so and as it heats up it goes down to around 700 800 or so and i can let the car run at idle for hours and idles perfect as soon as i push the gas the idle starts surging to about 2000 rpm down to 1200 and back and forth if i shut the car off for 20 seconds and start it back up its fine but as soon as i apply throttle it acts up again
now i have retorqued the cold idle air valve back in its seat fully replaced the IACV with a new honda IACV *expensive* and still does the same thing
if i pull the intake off and plug the top hole *IACV* with my finger while its pulsing idle drops back down to normal and i have alot of suction on my finger
and no check engine light by the way
i have a very little budget to put in the car after i pay all my bills etc.. so any advice to diagnose maybe the ecm for voltages or the tcs sensor would be greatly appreciated
thank you!
thank you!
