what should a honda delsol with a d15b7 at 9pounds of boost run. it also has a 2 1/2 inch catback exaust cut cat, fmu, b&m fuel psi regulator, msd btm, aem timing gear, no ac, no power steering, gst second gen blowoff valve, external ignition coil, rotor, and high flow fuel filter. what do yall think it should run
14.99 @93 MPH just a guess................
Re: Re: any honda sohc turbo hondas out ther
LOL hilarious on how you can just give out a time. I would put a border of -0.5 to +1.2 on that depending on the driver.
traction is the name of the game
you could run a 16.xxx just spinning your tires through 1st and 2nd gear
only way to know is to run your car
Re: Re: Re: any honda sohc turbo hondas out ther
because i run at the track all the time.........seen plenty of turbo d series cars down the quarter with similar specs.......it was a guess, but id say its pretty close to what it should run with middle of the road driving skills.
