i was wondering if anybody has had a problem with motor mounts?? i stripped the bolts on the upper driver side of the block. and i was wondering if there is any way 2 fix it w/out removing the motor??
You should be able to lift up on the motor to relieve the force on the mount to replace it. Put the car on jack stands and then place a block of wood between the jack head and the oil pan. You should be able to lift the engine just enough to remove the weight of the engine from the mounts.
