please provide more information. I assume that you are running premium gas. What plugs are you running? How much boost are you pushing when you get to 4krpm? What is your setup? What are you using for fuel management. Do you happen to have a dyno showing your a/f ratio?
swap the plugs out real quick for some el cheapo ngk's and gap them to .032 and see what happens.
also, check to make sure non of your plug wires is popping up and off.
what is the setup you're running and what's your fuel management setup like what kommon asked. Kinda hard to say what's wrong when you don't give any info :confused:
