illegal illegal illegal.
SpanishRicer said:I've driven in several Vtec equipped cars with their odometers disconnected, and Vtec engaged just fine.
lOOkatme said:I think it would still run without the speedo connnected. I wouldn't know why it wouldn't vtec it....isn't it run off of vaccum lines. besides I can hit vtec without flooring it as well.
Not to flame bro but I hit vtec when i hit 5500 rpm's I believe may be a little off and you do not have to hit WOT. I can take it out anyday of the week and do it I can downshift without hitting the gas at all and hit VTEC it's the RPM's not the throttle. That is proof enough what do you drive if you don't mind me asking.Asian-Stylin said:
there is no way you can hit VTEC without flooring. I don't think thats possible!!! If you can then I would really like to get a ride sometimes and see you engage VTEC without flooring it![]()
Downshift from 5th when your going about 70 to 4th you should hit it without hitting the gas just try it man it is all in the RPM's not the throttle reading. Cause if that was the case I could hit VTEC at 2000 RPM'sAsian-Stylin said:2000 Prelude Type SH
Maybe my car is just weird but I can't seem to hit VTEC without flooring it. Maybe I got the Melon of the Prelude bunch or something. Oh well, its all good.
I hit VTEC when I hit 4700RPM![]()
actually you won't be in vtec in 4th...in 3rd gear you would beInerTech said:
Downshift from 5th when your going about 70 to 4th you should hit it without hitting the gas just try it man it is all in the RPM's not the throttle reading. Cause if that was the case I could hit VTEC at 2000 RPM'sJ/K
what makes something more illegal than something else?? isn't speeding illegal...just like unplugging your speedoLudeboy said:Just remove the top 2 screws, pop the cluster out and unplug it.
Highly illegal though.
Thank you for that correction.lOOkatme said:
actually you won't be in vtec in 4th...in 3rd gear you would be![]()
So you are saying that killing someone is as bad as jaywalking because they are both illegal? That is an extreme, but maybe you would like to buy a car with an incorrect odometer.lOOkatme said:
what makes something more illegal than something else?? isn't speeding illegal...just like unplugging your speedo![]()
