From http://www.clubsol.com/techinfo_mechanical_2.shtml
The VTEC Performance Bar is a very simple performance upgrade with a factory part. This bar has the ability to be installed on every year & model delSol.
To install the VTEC Performance Bar you will need to remove the passenger front wheel. Once off; you well locate the CV axle and then slide the VTEC Performance bar through the different parts with the arch of the bar going in an upward direction. When the bar is laying in the proper position you will line up the mounting holes and fasten the bolts.
On the Si models there is a small bracket which holds a hose. This bracket is located in the far driver's side hole and can easily be bent to still work while have the bolt hold the bar & bracket. The easiest way I have found to tighten the bolts is to use rachet extensions to a point above the engine. Tighten all four bolts as tight as possible.
Part Numbers:
"VTEC Performance bar" - 50205-SR3-N11
4 bolts needed with the above - 93401-10025-08
Part Numbers:
