I need all the details on this F22B engine for the 4th gen preludes?
thanks- 96redlude0183
that's right... h22a, w/ no numbers after the a. usdm has the numbers, like h22a1.96redlude0183 said:i thought the true jdm motor was a H series motor.
the 4th gen JDM lude engine is an f22b, no 1 or2 after it...somewho in the original post i see no reference to 5th gen USDM accord engines.93OptimalLude said:ummmmm..........NO! All the info is above and correct.
I agree. F22b DOHC is a JDM engine from Japan. Accord/Prelude engine...which is made for accord and prelude..em...DUH!! Basicly the only different is the top which is a h23a1 from the Prelude SI...I believe......the botton is a f22 block which fits in all honda accord but of course....it could fit in any other car with some modification. Its pretty quick....as a matter of fact....I have it in my car!! HAHAHA~! I just got done with the swap...it was too easy. It doesn't have Vtec....but its JDM..basicly thats the point.v4lu3s said:lots of wrong info above
the f22b was used in 4th gen lude from 92-96 (obviously), its a jdm engine that produces 160hp and 148 ft/lbs of torque. its basically teh JDM version of the h23a1. Its dohc and non vtec as well.
they can be purchased for around $450-800 and will work fine on a non vtec ecu from a USDM accord.
Haha...its possible w/o too much trouble. F22b wid turbo will do fine....actually you will probably embarrass some of the accord with h22a for sure!! Hahahafizzbob7 said:its a 90 model and as far as wanting to turbocharge it, i just wanted to make sure it was possible without a lot of trouble....do u know if u can get headers, intake, exhaust, etc(jdm or us) for it.....im getting more and more interested......i luv the price...the difference would almost buy a turbo kit....i bet a turbo f would emabarass a few jdm h22a's.....at least i would hope so....i just wanna be fast enuff to get into trouble.....
