I was wondering if anyone is running a JRSC with a strut tower bar. For info on the car....look below. I am curious if anyone has had any clearance issues with these 2 together. Thanks
I have an LS....hence no stock strut bar
I'm sure you could get the GSR or ITR since its basically the same frame, just differnet engine?
Let me did up a couple of old pictures... I recall the nuespeed one works.
ITR one doesnt fit cause the map sensor is in the way, not sure about the gsr bar though. I tried screwing a thin metal plate over the map sensor hole and using that gasket glue stuff. It worked for awhile and i was running with the ITR bar. Then i had an air leak from it and everytime i fixed it i would get an air leak several weeks later. I just run with out a strut bar nowdays. If you want, give it a try and maybe yours wont leak.
