How much boost can i run on my 1.5 del sol? Here are my mods....
Turbonectics T3/T4 hybrid turbo, Vortech boost dependent FPR, HKS Racing BOV type 2, Drag Gen 3 manifold and piping, Spearco front mount intercooler, inline fuel pump, HKS turbo timer type 1, autometer boost gauge, TurboXs boost controller, DC Sports exhaust, Gude ported and polished head, three angle valve job, stiffer valve springs, ARP head studs, port matched intake manifold, Bullfrog camshaft, Hayame cam gear, B&M fuel pressure regulator, Crower rods, SRP 9:1 pistons(.010 oversized), JE wrist pins & locks, STR sleeve saver, Centerforce Dual Friction Clutch, Unorthodox crank pulley, MSD 6 BTM ignition w/ Boost retard knob, Blaster SS coil, MSD Pro Series Cap w/ high voltage coil wire, MSD 8.5mm plug wires
How much do you think the bottom will handle safely. Im currently running 8psi.
Wow, thats a pretty impressive D15. Its unusual that someone builds a SOHC. I'm not great at guessing the potential of modded engines, but I would say if everything was tuned right, then 12psi or more easy. I would recommend some more opinions though(like st00pid).
it depends on yer fuel supply.....you might want to invest on a standalone system to complete your car...then you can run as much boost as you want (15psi) til you get a real sleeve kit.
Discussion Starter · #5 ·
Who makes stand alones for my motor? Aren't they like 900 bucks or something?
