First, please stop using all caps...its harder to read, and on boards like this caps are used to mean that you are shouting.
OK, getting stiffer bushings does make the steering response of the car better, because they reduce the "play" of the suspension system (the movement of the suspension system that does not do anything but make the steering feel mushy). Incidentally, this is the main reason that I do not like coilover sleeves, they increase the play in the suspension system, so even though the stiffen the ride, steering response suffers.
As far as whether you need them or not...I doubt it. This is one of those mods that I would do only if I were racing the car (ie autox or track). For a daily driver these not only increase the stiffness of the ride, they increase road noise as well. There are other things that Honda suspensions need more to start with anyway...like stiffer rear anti-roll bars and better tires.
Oh, and if you do decide to get this done...be warned, you will need a ton of lithium grease on those babies every 6 months or so or they will start squeaking (all urethane bushings do this).
