Hello to all, I am fairly a new poster here and I have a fully built h22a running a 9:1 comp ratio sleeved and all with hondata s200, 450cc 255 fp aem fuel rail just about everything for the turbo setup of a t3to4e. Well, my dyno sheets do not show the power I am suppose to have. At 10lbs of boost I am only putting down 200 whp and 209 torqe. Anyone have any idea what could be causing this? Thanks
err... whats your A/F ratio like? From what i can remember, you really dont need the 255lph pump with 450's and hondata... but that could be car/setup dependant. Do you have a dyno to post? You might want to check out www.boosted-hybrid.com I think its related to your tune.... even with the 9:1 pistons you should be making around ~250- 270..... and they're also gonna need to check out your dyno + A/F plot to be able to help you....
Discussion Starter · #4 ·
the first dyno sheet is one of my first dyno runs since the set up. hope you can see something.
the 2nd dyno sheet was in feb 13 05
