SpanishRicer said:I gained close to 40hp in the midrange and about 8hp at the top end when I dyno tuned mine.
VTEC my friend, the low cams are when the vtec is off, and highs are when it's on. what he means by falling off is that the low cams start to loose efficiency as the rpm increases, so it switches to the high cams. the boost in power is just the switching over.JDMLUDE98 said:because of how the lowcam's power starts to fall off....what does that mean, does he have aftermarket cams, and if so which kind?SO the 40 hp in midrange isnt really felt,what it shoot 40 hp and what it drops?i'll start my serach now...thanks
that graph is pure bs though. look at where vtec engages on the lower line, 5800!!! of course the power sucks on the low cam right there! if it were at stock, you wouldnt see THAT big of a difference, but still a difference. anyone else notice how you can tell by that graph that stock vtec on his car is 5200?SpanishRicer said:Here's my old dyno chart that properly illustrates how to tune out the VTEC "dip" with a VAFC.
The red graph was my baseline run, before the VAFC was even fully installed. And my stock VTEC crossover was never 5200rpm, closer to 5500-5600rpm. Let's leave the constructive criticism to people who actually take the time to dyno their parts and share them with everyone.4bidden said:that graph is pure bs though. look at where vtec engages on the lower line, 5800!!! of course the power sucks on the low cam right there! if it were at stock, you wouldnt see THAT big of a difference, but still a difference. anyone else notice how you can tell by that graph that stock vtec on his car is 5200?
well then doing a run with it halfway installed fucked something up because NO h22 came with stock vtec cross of 5600rpms! if you look at where 5200rpms is on the blue line you can see that something changed there.....its the timing from when your car in stock form should switch over to vtec and the timing changes. that is a negative about the vafc, you cant change your timing to compensate for your lower vtec engagement.SpanishRicer said:The red graph was my baseline run, before the VAFC was even fully installed. And my stock VTEC crossover was never 5200rpm, closer to 5500-5600rpm. Let's leave the constructive criticism to people who actually take the time to dyno their parts and share them with everyone.
