my cars only done 27k but clutch squeaks already, think it might need some wd40crdcz03 said:mine squeeks when i push it in. if its like a squeeking noise then i wouldnt worry about it. unless you can hear it when the car is actually on.
ahhh but it squeaks not from the joint of the clutch to the floor or whatever, it squeaks from the pedal, the flat part...hhmm maybe you are right ill try cooking oil or something, i don't have wd40...hc99si1 said:my cars only done 27k but clutch squeaks already, think it might need some wd40
My stock clutch had that same noise/feeling. Finally (about 2 months later) the clutch gave out. When I chagned my clutch, the old one had RUSTY SPRINGS in the clutch disk. I was surprised they would look like that. It may be an early indication that the clutch is going bad.jc836 said:Generally this is a sign of a problem with the pressure plate and throwout bearing.
Sometimes it is the springs on the clutch disc that get loose.
So far as I know there is no way to lubricate any of these pieces to stop the noise you describe. If the release fork has a pivot point that may need a dab of high temp grease.
Just something to think about: Clutches can only take a certain amount of abuse before they fail. You can get up to 130K miles out of a Honda clutch-maybe more, but it requires a gentler driving style.![]()
94lude said:that noise is from the slave cylinder that goes onto the throw out bearing arm thing. if u grease that up it will stop for a little while (u have to have tranny our slave cyinder off) lube with ky jelly, i mean bearing grease....
