the 97 or 98 models do they have alot of mod potential?....should i get one instead of an Av6??
Agreed....munkeysoup said:A 1.8T A4? If so, then yes...they do have good mod potential. Chip and exhaust will get you 40-50 whp for $1000. As for taking it over the av6, its all up to you.![]()
You probably don't know much about VW/Audi engine then. The 1.8T A4 is a I4 1.8L turbo. You could add a chip (APR) and change the air filter with K&N one for around $500 (reusing your CPU). This upgrade could land you another 40hp and ton of torque (up to 240 lb-ft I think).FadeToBlack said:are there superchargers available or turbos?? and what about body kits any nice one?
bachviet said:You probably don't know much about VW/Audi engine then. The 1.8T A4 is a I4 1.8L turbo. You could add a chip (APR) and change the air filter with K&N one for around $500 (reusing your CPU). This upgrade could land you another 40hp and ton of torque (up to 240 lb-ft I think).
