Audi has released details of the new RS6, the most powerful model imo.
It will be fitted with a 4.2-litre twin turbo V8 engine pushing out no less than 450bhp, with maximum torque of 412lb/ft available from 1950-5500rpm. Tiptronic transmission is standard.
What all that means is that the RS6 bullets to 62mph in 4.9 seconds and has no difficulty getting to the familiar governed autobahn top speed of 155mph.
It's hoped that first supplies to the UK will arrive in September. No prices yet, but Audi says they will be "quite competitive".
no six speed manual? I hope they change their minds. now that thing is just two of my cars put togeather.
Audi wanted to bitch slap the M5 and it looks like they're raising their hands. But BMM (//M) is laughing cos it takes a bi turbo V8 to do so whereas M5 is N/A :eek:
Discussion Starter · #8 ·
02 Audi RS6 info:
The RS6 has been created by quattro GmbH as an entirely independent model and developed in conjunction with AUDI AG. The V8 biturbo engine of the Audi RS 6 has an output of 331 kW (450 bhp) and is has capable performance of a thoroughbred sports car.
The Audi RS6 is a unique high-tech package. Its immense power characteristic, quattro permanent four-wheel drive, high-tech brake system and innovative DRC suspension set new standards in the segment of high-performance vehicles.
The V8 engine, displacing 4.2 litres, has been specially developed for the Audi RS6. It achieves a permanent maximum power output of 331 kW (450 bhp) between 5700 and 6400 rpm. Its peak torque of 560 NM is available across an extremely wide range of engine speeds, from 1950 to 5600 rpm.
In keeping with the car's high performance, quattro GmbH has developed a completely new brake system for the RS 6. Large brake discs of a composite design have been fitted on both the front and rear wheels. This technology, which originated in the world of motor sport, involves fixing a cast friction ring to an aluminium brake-disc chamber by means of 14 pins. This "floating" arrangement improves the stability of the brake discs, particularly when exposed to extreme loads and at high operating temperatures.
The Audi RS 6 is the first model to be equipped with the innovative suspension concept Dynamic Ride Control (DRC). It denotes a special damping system which counteracts movements of the vehicle along its longitudinal axis and transverse axis. Both shock absorbers on the same side of the vehicle are connected with the diagonally opposed dampers on the other side, each by means of one central valve.
When a corner is taken, a flow of oil and thus a supplementary damping force is generated via the central valve between the diagonally opposed shock absorbers. When the suspension is compressed on one side, the damper characteristic is modified in such a way that rolling or pitching movements are almost entirely eliminated. As a result, this alert, mechanically active damping system ensures that the RS 6 maintains extremely good tracking stability when cornering and responds precisely to adjustments of the steering wheel.
The Audi RS 6 is an independent model that has been created by quattro GmbH and developed in conjunction with AUDI AG. It is being built jointly at Neckarsulm by the Audi plant and quattro GmbH. The RS 6 is assembled and finished at quattro GmbH's production facilities, at the rate of no more than a handful of cars each day, in the best handicraft tradition. This approach assures supreme product quality and has already proven notably successful for assembly of the RS 4, of which 6030 were built between September 1999 and July 2001.
V8 with 5 Valves per Cyl w/2 Stage Intake makes 450.0 bhp @ 5700-6400 rpm and 413.0 ft lbs @ 1950-5600 rpm. 0 - 60 mph 4.8 seconds,. No 1/4 mile was given.
here's a rear pic
9000RPM said:
Audi has torque to burn though.
RS6 -> 4.2L pumping out 450 bhp (56 more than M5) and 560Nm (60 more than M5). Most interestingly is that it's maximum torgue occurs at very low rpm and ranging from 1950-5600 rpm....Should be able to beat the M5 but no....
M5 -> bigger displacement (4.941L - better measurement for a V8) and better technology. M5 will pull RS6 back.
