b16 exhaust
hey, im getting a b16 engine swap and I was wondering, what kind of exhaust do I need? would a cat-back exhaust made for the crx work or do I have to use an si exhaust? Or should i get one custom made from a shop?
i assume it would...before i got my b16, i had a greddy cat back exhaust on my car. when i got the swap, it bolted right up. i must warn you though, it rattles quite a bit. im not sure if its because the exhaust system is getting old and the brackets are worn, or if it is because i wasnt supposed to use it with my b16??
I would get custom exhaust just cuz its what i like and youi know what it is going to look like in the end. But once mine is in I will have an open header :D , i don't follow local laws lol.
ya it not supposed to bolt up because the crx(if it does your going to run into problems) did not come with b16 over here and header length is different between the b and d.
