alright first off i would like to say that the b16 swap is awesome. but i am having a couple problems well i guess they arent really problems just concerns first off can anyone with this swap tell me what RPM you run at around 50, 60, 70 so on and so on cause i am running about 3200 at like 60 and i wasnt reallly sure if that was right. and the other thing is i am geting code 22 which is the VTEC oil pressure sensor and i wasnt sure how to fix it. any help from you hguys would be great.
I have a s1 trans in my car and it does the same don't wory just enjoy,
but you get shitty fuel milage on the highway. as for the sensor I would check for shorts to the ecu or make sure you wired it right to the ecu, or the sensor could be bad. hope that helpes some....
