hi was wondering i a have b16a block. i am able to pick up on gsr rods n pistons for cheap. the only difference is that the stroke length on the the gsr rods is shorter by about 0.2 ... also would it fit around a b16 crank... also how much would the 0.2 throw the motor off or what would it do. thanks
no, no, no...don't do it!!! You will seriously F that engine up!!!! Too much other shit you would have to do to make it work...stick with the standard B16A parts for that car as there are plenty around!!! Is just the block a B16?? Are you try to build some sort of hybrid motor??
i have everything but pistons and rods yes it is a b16a block. reason i was asking was because i can get gsr rod and pistons way cheaper that b16.
