I only got a weapon r intake and a apexi n1 exaust
with 50 shot nos will this meess up my car
I have a 99 civic si
No, 2 heat ranges colder will be all you will need for a JRSC'd car with NOS.will i then need to go and ADDITIONAL 1 range cooler on the plug?!?
Or buy a MSD window switch or Jacob's nitrous mastermind. Rev limiters are wonderful things.VTECsqznN2O said:Lastly, dont use the wide open thottle micro switch that comes with NOS kits, if you miss a shift you will go wide open and spray at 8000 rpm.
well if u miss shift as long as u dont have ur foot on full trottle its should be safe. just be more careful. button and trottle button is just a preference thing. depends on wat people like.VTECsqznN2O said:I have a b16 in my hatch and im running 50 shot on it..the spark plugs you wanna use are NGK BCPR7ES-11 . Retard your ignition timing a couple degrees and you will be cool..Also, invest in a fuel pressure regulator and push the pressure to around 46 psi. This will prevent it running lean..Lastly, dont use the wide open thottle micro switch that comes with NOS kits, if you miss a shift you will go wide open and spray at 8000 rpm. Go to a manual button near your shifter.
