NO NO NO NO. Head work will not allow you to do a 150 shot. Head work isnt going to do much for you. The problem lies in the pistons, rings, and the cylinders. Those are the weak points. You will crack a sleeve or blow out the rings long before you do anything to the head.Are you can go with nitrous express don't go dry shot a lot o people blow up with that if its a stock b16 do a 75 shot are under if the head is wrk u can do 150 shot
exactly....if it was me just do a NX or NOS wet 50 shot and you'll be fine just dont use is all the time like i did and blow head gaskets left and right..lol you could do 75 shot but then your going to have to retard your timing and get colder plugsNO NO NO NO. Head work will not allow you to do a 150 shot. Head work isnt going to do much for you. The problem lies in the pistons, rings, and the cylinders. Those are the weak points. You will crack a sleeve or blow out the rings long before you do anything to the head.
lol kev...I have run a 50 shot dry on a stock block b16 for about 6 years now and havent had any problems with it. I just recently stepepd up to a wet kit and havent decided what shot i want to run..
you can do a 30 40 50 shot adjustable 2 ways...you would either, A. have to run multiple kits at a really low shot like a 25..and the second kit another 25 shot so it would equal a 50..but thats a lot of extra bs for a street car and a 50 shot...
your next choice would be to run a progresive controller, however that only limits the shot size for 1-5 seconds..thats meant to jsut allow you to hook up your tires and not spin out of the hole...
the only reason i suggestued such was because he asked about doing 30, 40, 50 limitedlol kev...
i ran a 75 shot for about 7 years on my B18C. no need for a progressive controller just buy a set of drag radials and squeeze on the launch
You still owe me a 10sec carand why does every noob call it "NOS" do you call every car a mustang?
100% correct. You want to retard the timing. He was making a joke. Either way I deleted the post to avoid any confusion with people looking for legit information.from what i have been reading on all these other sites you dont advance the timing at all you need to retard it for nitrous
