B16B
guys,
the B16B encorporates a B18C block for the taller deck height. It has a B16A Crank and longer rods to aid in the higher rev range.
A longer rod provides more torque down low due to the longer dwell time at TDC.
Personally either choice would be a good one, and both would be safe for boosting, provided the engine is built properly with forged rods and pistons.
If it were me, i'd go with the B16B as the crank was designed for higher rpm. And if you ever wanted to, you could replace the crank for a B18C crank, since the block is actually a B18C block.
DelHop
