I'm replacing the water pump on the B16B before it goes in.
Does it use the same water pump as the 2000 Integra Type-R?
Does anybody have the Honda/Acura OEM part number?
I've been told to use only Honda OEM parts on my motor (which makes sense) and I've also been told that Honda does not make water pumps, someone else makes them for Honda and it won't hurt to use a NAPA or etc.
So which way. Type-R pump from acuraautomotiveparts @ $100 + or decent one from Napa, Autozone. I saw one online from a part store with brass blades? Anyone seen this before? Know any pros' cons'?
Do you guys replace you timing belt tensioner & spring at the same time as the timing belt, water pump change out?
I know it's a lot of questions but I appreciate the support!
Discussion Starter · #2 ·
I got the part # from another forum for the type-r pump: 19200-P72-013
I got the pump, tensioner and spring from prostreetonline.c__ for $141 shipped.
They told me they purchase their parts from the manufacturers so they may have some with the Honda name on it, it depends on what they have on the shelf and who pulls it.
They said the tensioner and spring will definetly be OEM.
Exact same part number as the ITR/GSR one's.
