jacnife said:
my friend wants to know if he puts ctr cams in his b17 do he need to upgrade the valvetrain? and is a valve adjustment neccesary when upgrading? Also can he put ctr pistons in a b17 without modifying the rods. and how high is the compresion ratio going to be? And will it be good if he milled the head, if so, how much should it be? hope someone can help
ur friend can get away with his b17 vavletrain as long as he keeps his stock rev limit. valve adjustment is necessary after every cam install to make sure that everything is in spec.
ur friend can install the ctr pistons as long as he "modifies" the b17 rods to accept the vtec pistons easily.
(pic courtesy of
www.ff-squad.com/pistons.htm)
compression ratio for b17 engine with PCT (CTR) pistons = 11.46
i suggest that u order some CTR pistons that are 25 mm over. have the machinist bore the sleeves 25 mm over also to make em fit nice and snug.
if u want to keep the same bore (81 mm) then get the 81 mm pistons. but the compression will go down from 11.46 to 11.41
milling the head should only be done just to keep the cylinder head's mating surface level. milling the head to gain more compression is a big no-no. it might lead to compromising the specs for piston-to-valve clearances and ur friend might end up having holes in his pistons. just use a thinner head gasket instead if u want a little more bump in compression.
hth.
