can i put a vtec head onto a b18b1 block qithout changing anything else? if i have to change the cpu settings or the whole cpu i dont know if ill have the money. If i cant do this can i at least put the vtec valve cover onto the non vtec head since i just got it powder coated? thanks
Yes a vtec head will bolt on to a b18b1 but you have to change the dowel pin (pins that make the head line up on the block) hole size on the head. and put a plug in the oil galley on the head. and you have to use the stock b18b1 head gasket. vtec will not engage unless you change the ecu and put and oil line from the back of the block to the oil plug on the back of the head. and no a vtec valve cover will not bolt on to a stock b18b1 head.
