Had the motor running for months now. Just this past week been having starting problems, NOW its dead. It cranks, sparks, and there is fuel, but doesnt go. Once in a while you can get it to almost start if you keep cranking her, but she wont break free!
CEL: 41 Primary oxygen sensor heater ??? where can I locate that?
Motor is in a 92 Si hatch.
Any ideas to where to check next?
Tony
a bad o2 sensor in it self should not keep the motor from starting
double check your timming (the timming belt not the dizzy)
also have you changed or done anything lately ??
lastly, and this is a long shot, if your cel code is 41 its a probleme in the o2 heater circuit could b a short or ground in the wiring and that would mess up the ecu, or (long shot) your ecu is the one causing the short try switching it with a proven good one
hope this helps good luck
