do not use the integra harness unless you like headaches....the HF/SI harnesses swap right over, there are only 2 differences, 1 is the EGR (integra does not have it UNLESS it was an automatic), and 2 the oil sending light plug (i think thats what it does).....other then that the other harnesses swap right over........like he said if its not starting then you need to see if you are getting spark, if you are then its a fuel problem, if you are not then thats obvious..........did you check your main relay?
