Hopefully someone can Help. Converted a B18a1 LS block to VTEC using a JDM B16a DOHC head. B16a Pistons from WIESCO, Eagle rods, Skunk works Dual titanium valve Springs. Put engine in. It started the first few times no problem ran it for about an hour or so that way. Now it seems that the PCM is telling the PGM not to send signals to the fuel pump nor injectors. Will still start with starting fluid. any Ideas. PGM relay does check out good. thx
