Is there any point in building an oil cooler for this motor? and if so what cars at a wrecker yard had old oil coolers i could modify to fit this app
OBD1 GSR's had oem oil coolers, 94-95. G2 GSR's had them as well. All ITR's had them standard. Prelude had them as well. S2000 has them too. Some Accords and Oddessey's had them from the factory plant.
Probably the easiest is the OEM ITR or 94-95 GSR's as they are made for the teg. However findong one and looking for one F/S is hard and expensive even used.
Might as well get an aftermarket one that is mounted in front of the radiator or something for more efficientcy. OEM ones are cooled by the coolant FWIW.
