1 - 16 of 16 Posts
I have a 1999 two door civic and i want a fast car that is streetable and i can't decide if i should go with a b18b with a turbo or a b18c5 and go all motor. i have heard that a b18c5 with a turbo isn't i good idea so i don't know what to go with....any opinions?
The B18C5 is fine with boost if you lower compression, I say B18B with a turbo though. You will have alot less invested and get more gains out of it plus you will have what is most important and that is tq
Discussion Starter · #5 ·
if i go with the b18b with boost the compression should be ok or will i have to lower it....i haven't read anything that would suggest that the compression would be to high for boost
Put it this way. I have a B18C EK hatch. it's fast, I love it. I also have a friend with an Integra (B18B) turbod and 10PSI. He would walk all over me in a streight line. I am a better driver and would win on a road corse.
if I had it to do over I would go B18B Turbo
96civic3door said:
A bone stock B18B with a correctly designed turbo setup and tunned correctly can put you in thw 250 to 275whp range.
werd.
werdageness x2
mucivic said:
Do you disagree?
lol I just agreed twice.
A b18b turbo should produce 220-250whp at least safely....as well as an equal amount of wheel torque.
A b18c5 will produce maybe 180-195 hp if you are lucky and shit for torque.
Do the math...which is better?
:p
:ninja
1 - 16 of 16 Posts
