ok guys i cant figure it out... im boost 10lbs on my b18c and in low cam everything is fine and dandy but when vtec comes on and in high cam its start skipping alittle and popping and i let out of it... now i have enough fuel im sure of it... wb255 and rc 750 injectors... would it pos be the timing and i need to turn it down more or where should i look? any suggestions would be nice and if you need more info plz ask thanks
Have you had your set up dyno'd? If not it sounds like you're dumping too much fuel. I'd bet you're running stupid rich in the neighborhood of 9:1. I'd check your air/fuel mix before checking your timing. But the 2 kind of go together.
