I'm just kinda of curious if the B20 crank and rods will fit into a GSR. I'm not sure if the decks are the same height, but i think they're different. I just wanna know so if this is possible. If it is, I can put down alot more torque and the reliability of a GSR block.
The B20 crank can probably be used in a GSR block. But since the B20 has a longer stroke, you will probably also need shorter rods. I believe the B18C and B20 have the same deck height. So B20 rods will also work. Keep in mind that the B20 uses the same crank as the B18A/B18B. And since using this crank will result in a measly displacement increase from 1797cc to 1834cc, I would not bother. You would probably not even feel it. And revvability would suffer since your rod ratio would drop from 1.57:1 to 1.54:1.
The B20 gets the bulk of its displacement increase by using a larger bore diameter (84mm vs 81mm for other B-motors, including the GSR and LS). You could gain quite a bit of displacement on your GSR motor by resleeving it to run 84mm or 84.5mm pistons. This will give you a displacement somewhat over 1900cc with no sacrifice in rod ratio.
The B20 and the B18a/b have the same stroke, but I believe the GSR have a short stroke than those two. This gives the B20 and B18a/b to have more torque.
Somebody told me this would not work because the deck height of the b20 and the GSR have different heights.
The LS and B20 do have longer strokes than the GSR. But I believe they share the same deck height. This helps to give the GSR a better rod ratio. By the way, the LS does not have more torque than the GSR. But the B20 does.
b20 crank
i have a b20 and have spent countless hours researching b20 shit , the b20 crank is the same as the ls on it is a litle heayier duty, whichi would think that means it is less of a performance minded crank then even the ls i know that is will not give you anymore displacement then an ls so if you are doing it just to say you have a b20 crank then go ahead but it will not do much for you if you want a good resource site for b20.vtec stuff try http://www.crvtec.com it has a lot of interesting thing that you may not know
