Waz up?
I know there has been many question about this swap, but the thing i can't find out or firgure is , if a b16 or b18 head can rev up to 8-9k mod. How can a b20 block hold that if it only meant to rev to 6-7k ( not sure on redline). What is need to build thie motor correctly without worrying when you might blow it up. And what ecu do you use for this set-up? I know proper pistons and rods are one of the things need , But what else is need if your going to boost on this motor?
