Sooo.... i've spent allllll day trying to find out this problem.
Does a 00, obd2 obviously, b20b have a Crank Position Sensor? This is the sensor that i've seen on every obd2 motor that is down on the bottom of the block by the crank pully.
I've purchased this motor and it doesnt have one... weird... and it was in an EK hatch... running perfectly. I test drove the motor and everything.
the mechanic doesnt remember if he ever disconnected this sensor or not, and with that said, assured me that he had not removed anything off of the block either.
so if what he said is true, and he didnt remove anything... why does this obd2 motor not have a Crank Position sensor?
