1 - 8 of 8 Posts
the stroke is long and the rod stroke ratio is terrible, so it weaaras internally a lot mroe than most engines from honda.
the h22a i know id 87mm bore i forget the rerst stince its not someething i iworry or think aabout often, use google its easy info to pull up though.
Discussion Starter · #5 ·
Well those were the two engine choices other than the b16a and the b16a2 moter i was pondering about any suggestion for the 98 civic dx which now has the 1.6 in it and cant really think of anything to pick up the power for it
b21a1
specs:
burn me and urinate on me because i am good for nothing
LOSTCIVIC said:
Yeah compression, air to fuel ration, spark plug gaping, timing and injector see if its run hot to see how well the cylinder walls hold up
don't bother even attempting to build that motor, it is shit and has nothing in common w/ the other b-series engines other then the "b" in its name
1 - 8 of 8 Posts
