i have a 95 D15B7 with some problems. the motor is strong all the way to 7 grand (usually where i shift when i race) but when at idle after the motor is fully warmed up the rpms pulsate between 500 and 700 or so and i have a very accurate tach! the whole car vibrates when i sit still at idle but if i push the gas ever so slightly it goes away! what is causing this??? and when i first start the car for about the first couple of minutes when the motor is really cold the motor jumps about 500 rpm's. if i let the cluch out in N it goes away!! WTF???? i mean i sit at stop signs and the motor is idling a little above 1000 rpm (the motor is cold) and it jumps to 1500 and then falls down, it does this really fast! can anyone tell me what the problem is???
thanks!
thanks!
