I have a 95 integra LS automatic non *****. I just bought this car about a week and a half ago from a used car dealership, when i first got it the car was fine accept for the fact that when you tried to floor it the car would buckle and not do anything after about 3 seconds of trying to floor it. When i found this out i didnt try to do it anymore. I changed out the sparkplugs and the spark plug wires thinking maybe that was the problem, the spark plugs had motor oil on them and there was oil at the bottom of the spark plug cylinders. It didnt help any but it didnt hurt either. A few days later the car started sputtering a lot and its getting worse and worse. When i first start the car up it will idle at about 1500 rpm's and then after a while it will drop down to below 500 and then sputter and each time it sputters it drops it down to less than 100 rpm's, so low that the a/c cuts on and off each time it sputters when in idle. I do know that the transmission was rebuilt on the car but the car shifted perfectly when i first got it. Does anyone have any suggestions?
