try using some 44k its an incredible fuel additive by BG. i've seen it solve this problem in the past.
qbsi said:i think bad piston rings might cause the problem.
if you're getting tons of smokie, im pretty sure thats the problem.
Maniac said:Worn or weak piston rings will cause lower compression and increased oil consumption. It will be blowing blue smoke all the time.
One thing I forgot to add to my previous post. One way to tell if you are burning anti-freeze is that your coolant level will be low, obviosuly. You can test for a blown head gasket by pressurizing each cylinder with air. If you remove your rad cap and see bubbles coming up as you test each cylinder you will know that it is indeed a head gasket problem.
My advice is, if your collant level is low, take it to a garage and get it checked out. Most people don't have the equipment to do these tests properly and they aren't terribly expensive to get done.
sl33per said:so it has nothing to do with gas? why am i getting bad mpg? and when i drive the car hard, i hear rattling sound from inside the engine. could it be the valves? im gonna get a compression test this week and thanks for the infos..
qbsi said:i ment to say good info Maniac.
