basically,wat ls/vtec mean is a ls block (b18a/b) wit a vtec head (b16,b18c,c5).....its gains hp n torque, doing this, u can run itr time or even better better, depending on wat u do,if u just put gsr ecu,water pump,timing belt, ls pistons,etc....ur looking at itr time,if ur a good driver then ull do better......on the other hand, if u build the engine wit ir intake manifold,itr pistons,ecuetc and all that, then ur looking a probably mid 13s, maybe better
All depends on wat u do n a driver that u are!
